Цитата(Serjik @ 17.6.2007, 1:16) [snapback]287919[/snapback]
Дай ссылочку , если будет время , то переведу .
Вот что они здесь замышляют???
"2003-2005 Snorkelectomy
This is so easy, even I could do it.
Just lift the gas tank by removing the two black triangular plastic thingys, each with one bolt under the seat on each side and then removing the seat. Then take the two bolts out from the front of the tank. Now is a good time to add those washers for the tank lift if you were going to do that.
Take the cover off of the air box by removing like eight screws that stay with the box so you won't lose them. There is a snorkel-looking thing on this piece. Just take your hand and pop the snorkel out. That's it. Sound too easy? Well, that's all it takes.
You will gain like 3-4 mph on your top end. I went to sustained 133mph to a sustained 137mph on flat ground. The fuel injection does not seem to be affected and it even gives it a good growling sound. Not as good as pipes, but second best. The bike runs better through all ranges of the tachometer and has just a little more oomph it seems.
Try it. You WILL like it. "
Ещё здесь какие-то шаманства...
http://www.geocities.com/catpoopman/sv650_snorkel.html
